This could probably be a general question, but since I've got an Atlas lathe, though I'd start here. I'm learning to thread and have had some success. My question has to do with various grades of steel for threading. I'm cutting basic 1/2-20 threads. I started with some 1/2" steel from a local fabricator, and after a few failed attempts, got to where I could somewhat consistently cut threads onto which I could pretty easily screw a nut. I then got a piece of 1/2" steel rod from Tractor Supply, and I haven't been able to create a thread that I can get a nut on for the life of me. To test whether it was my setup or the metal, I tried the identical setup on a piece of 1/2" aluminum, and that worked.
One of the things I noticed about the TS steel is that the cut wasn't very clean--lots of rough spots, burrs. etc. Once I finished the thread, I could get the nut started--about a turn--but it wouldn't go further. So I'm wondering if it's just the quality of the steel, given that I was able to use the same tooling, speed, etc. successfully with the other steel and the aluminum. Or, does it sound like I might be using the wrong tool or speed, etc. with the TS steel? Thanks.
