OK, so I've been trying to thread a piece of pipe 3/4-10 as part of a hand crank for my 9x30 lathe.
(Problem 1, of course, is that I don't really know what the pipe is made from. It's a scrapyard piece, but by dimensions etc, it appears to be 1/2" nominal schedule 80 steel seamless pipe)
I ran into something interesting that I don't understand, though.
I did what I usually do - I turned the diameter a couple of thou's under (0.747, I think in this case), and set up for threading. 30 degrees, fish tail, blued the OD, all that. I took passes of 0.003 until I was down to a razor's thin line on the bluing then started checking for fit with a nut.
Couldn't get it to fit no matter what I tried. The pitch was right (first thing I checked), the initial entry/champher was ok. I finally tried running a die down it, and couldn't get that to pass either (even with signifigant work.) I checked the pitch diameter with the three wire method and it was ok. Curious, I checked the OD with a mike. It had grown from 0.747/0.748 to 0.756.
Is this steel just really really ductile and being "grown" as I take passes? 8 thou seems a lot for that. Or is there something else going on?
More importantly, how do I fix it?
What I did this time was, knowing that (with the three-wire test) I was at the right pitch diameter, I decided to just shave a few thou off the OD. It didn't really work well - but I could get the nut to fit and eventually made it work. It was a one-time screwon anyway - I locktited the pipe into the handle and figured the extra friction would help it to hold, but I'm curious about the "right" way to fix this.
