threading help please
Investigator
H-M Supporter - Gold Member
Jun 8, 2016
640
I need to understand cutting threads on an non-standard diameter. For example, (making up numbers) if I had a 1.133"OD and wanted to cut threads at 20tpi (or any other pitch) how deep do I need to cut them? I understand looking up major and minor diameters for standard sizes, but what about one offs?
Wow where do you find that calculator? I just made up the diameter for discussion
I do a lot of oddball thread stuff in SAE (at home) and metric at work. I measure threads at work and the numbers have to be perfect with regard to JIS standards for metric threads. I started using a program called "ME Threadpal" a long time ago when the program designer first made it available. It has features that allow me to make threads up that I really like. I couldn't tell you if the program is even still available since it's been so long.
I realize that there are lots of ways to get close to the answer you're asking for, this was just one of them.
I would be interested in finding another way to calculate odd ball threads.
I do a lot of Amish Sawmill repair and some is beyond repair but you have to use what not broke up.
Most all shafts are fractional in 1/16 2 7/16 1 5/16
They do not have a answer only that's it's the way it has always been.
