- Mar 3, 2020
- 195
I'm threading HDPE.. buttress threads. I had the material form rather than cut, so I turned down the scrap to about 3/4 and am doing some more experimentation.
The first pass (shown) was cutting half the length and then started to simply deform.
Then I had a couple passes successfully cut.
Then I had a pads deform the material rather than cut.
Is there a trick? I'm going to play with the rake and angles. I searched the web but didn't see a lot specific to HDPE.
Thanks.
Thanks.
