- Feb 27, 2012
- 158
Hello, I never got a lathe yet, but I am planing a future project for when I get my lathe. I will have a piece of ss rod,probably 440c, it will have a OD of about 1/2", with a hole drilled in one end about an inch deep, and I need to thread it from just about the bottom to about a 1/2" to 1/4" from the top. So, I will have threads about a 1/2" to 3/4" long starting at the bottom of the hole and coming to the top. Because the threads need to be just about to the bottom of the hole, I am thinking if it is able to be done, start threading at the bottom and work towards the top of the hole. Would this be done by reversing the spindle and reversing the power feed? The threads I would be cutting will be standard RH threads, I am not sure of the size right now, I could check the size and the dimensions when I get home if that matters.
The reason I am thinking of doing it this way is so I don't have to worry about stopping the power feed at exactly the right time. I am worry that if I let the power feed go a second to long it will crash into the bottom of the hole.
