Threading dies
Brento
May 9, 2018
1,721
I have a Snap on die that has an adjustable screw. Now iirc dies with an adjustable screw. Usually are cutting the threads and not chasing correct? I also have a die downstairs that is a round die from Dunlap and also wondering if that would be a cutting die or chasing.image.jpg
round dies cut threads hex form threads so that they fix damaged threads without making it too small.
Ok this is like a tripple hex lol due to being from snap on it prob forms threads.
The adjustable die is used to make different thread tolerances. Thread tolerances are expressed in "H" limits. A thread made to the exact size of the nominal size is an H0 (as in zero). Each .0005" over the nominal size is one H size larger. For an example a 3/8-16 H1 thread is .0005 larger than the .375" nominal size, an H2 thread is .001" larger, and an H3 thread is .0015 larger" If I recall correctly H limits go up to H12. Those over H4 or H5 are usually used when threads are cut then the part is plated.
The adjusting screw allows the die to be enlarged to meet the H limit required. The most common for fractional sizes is H3. Smaller number sizes are usually H1 or H2.
As for hex dies being for rethreading and round dies being for thread cutting that is a general rule, but not necessarily a hard and fast rule. I have hex dies that are thread cutting dies. They're generally used in tight places with a socket and extension where a standard die wrench would be difficult or impossible to use.
I have a full set of Snap On "triple hex dies" like this:
They are thread cutting dies that can be used in either a die wrench or socket.
I use the hex type die. the only difference is the is the adjusting screw to fine tune the thread fit. Both work well in cutting new or chasing existing threads
Those are the exact same dies i have that i am talking about.
Please be aware that using a thread cutting die to clean up rolled threads (i.e. bolts) will cut the root out of the thread thus reducing the bolts capacity by about 30%.
Where did you get the 30%?
Got the 30% from a technical article I read. Don't remember exactly where. The reduction in strength comes from the die cutting the rolled root from the thread thus creating stress raisers.
I'm not disputing that there maybe a reduction in strength. I'm curious as to who came up with the 30%.
