- Nov 28, 2010
- 26
A while ago I posted about my CW mortar project and mentioned that it was on hold for a while because of other projects. One of those projects is a threading dial for my Star lathe. While threading the breach plug for the mortar I had to keep the half nuts closed all the time so as to not lose the thread. This meant a lot of hand cranking. A thread dial would have been a really big help. I had made one for my W C Young lathe that I used for the internal thread and it was a big help. So, the first step in making the device required a mating gear to be made. The lead screw is a 9 thread. Somewhat unusual but it works. That said, I wanted a 36 tooth gear with an acme profile. I had hoped to make it from aluminum, but didn't have any on hand of the needed diameter. I did have a bunch of old wire sizing dies that looked like about the right diameter. I took a stab at grinding a fly cutter to the approx profile of the thread and used a spin index blocked up to get near the matching slant on the teeth and started cutting. I'm quite satisfied with the result. The pictures are not as clear as I would like, but I can't figure out how to get this camera to take good close ups. It' a Cannon Power Shot 550. Any suggestions would be appreciated. I still have to make the mount for the device. I will post pics as I progress. John
