- Oct 12, 2023
- 148
Well, got the lathe back up and running and was looking for a project to start on that would test my abilities to follow a set of drawings. Then the other night we discovered an armadillo den between the neighbor's house and ours. Which made me think about suppressing my Mk4. I don't have a .22LR suppressor, but I do have an Omega 9K that accepts a threaded adapter. The only really critical dimensions are the threads. 1/2-28 UNEF for the muzzle, and 1.125-28 UNF for the suppressor side. But I did measure out the original 5/8-24 adapter to use for the drawings. Aluminum rod for the practice round, then either 4140 or 416 stainless for the final part. I haven't even started trying to figure out which would be the better option so any advice would be appreciated.
Preliminary design stuff
I'm also trying to get better at CAD, so here is the attempt. I did have to look up a couple things, but the majority I was able to remember how to do.
Chucked up in the lathe and turned to the 1.200" overall diameter. As you can see that is steel. I attempted to thread away from the chuck without rewatching the Joe Pie video, and ended up cutting left-handed threads, lol. So now it's a restart with the 4140.
A couple questions.
1. What strategy do you guys use when setting up to hit the Y-axis dimensions? Do you face it then mark that the zero, then watch the DRO while traveling towards the chuck to hit the mark? Or would you work your way backwards from the 1.2" ring turning to the major diameter and then face off before starting the 1.125-28 threads?
2. How do I get the threading insert (or HSS tool) to reach the centerline for threading? Pic below for clarity, but there's no way that I can see to get the insert at the proper level. I run out of travel way before. In the Joe Pie video, it looks like he has a shop made adapter that allows for higher placement on the tool post. Any ideas?
A couple questions.
