Thread cutting advise / tools
liteace
Hi ALL, Im new here, I hope I have posted in the correct place, if not please move.
To start with, I hope your all doing as well as you possibly can in the current situation and I wish you all the best
I have a valve, one side has a thread of 1/4" sae, this is the side I need to work with, what I need to do is drill and tap a plastic block, screw this in and try make a tight seal, as I have no access to the other side / inside of the block, any tips on the best way to do this to get a good tapered seat for this to seal on. also what size/type drill bit and tap would need
I also have a pressure gauge that I might need to use with this, the gauge has 1/4 bspp thread with a small aluminum sealing washer, again need advise on drilling and tapping, as this has flat seal do flat drill bits exist for doing this kind of work
Thanks
Ahh - an adapter. SAE is widely used for solenoid valves. NPT is tapered, like BSP.
BSPP (the parallel thread) will seal if offered into the tapered BSP.
I always used some PTFE tape. When both the male and female were BSPP, I used a Dowty seal, or sometimes I just cut some chamfer to accommodate a thin section O-ring. Getting a pressure gauge to seal was no problem.
For the SAE end, there is lots of information on threads and sealing. I am less sure about making it in plastic, but I am sure someone at HM knows how.
https://www.hydraulicsdirect.com/Fitting-Thread-Chart-s/1934.htm
https://www.essentracomponents.com/en-us/news/product-resources/identifying-threads-and-connectors
https://www.ryco.com.au/technical/thread-connector-identification/sae-threads/
https://trimantec.com/blogs/t/thread-identification-guide#SAE-Chart
After some google'ing it looks like the 1/4" sae was also used on the early vehicle R12 ac systems for the charge ports, I'll have to look into that as well
