I messed up this evening in chain of events I had not foreseen. (I guess all mess-ups are not foreseen?)
On the 3" 5-cutter carbide face mill and 2" wide Ti 6-4 I had figured out I could do .002 depth cuts at 700 rpm without any spark shower.
When much to my surprise a had a torrent of sparks. Way more than anything I had ever seen. Not just beautiful. Honestly scary. After a startle reaction time (1 second? Maybe 2?) I stopped the feed. Spark shower continued, only slightly diminishing. I worked my way from the right side of the machine where I was feeding from and hit off. Sparks stop.
Diagnosing the problem, the .002 feed was way off. I never figured out how much--maybe .010?
The problem turned out to be the Z-axis DRO mounting screws had worked loose. Screws were rattling. I went through them and tightened them up. Will put some aluminum stock in tomorrow and reestablish confidence in the DRO.
I had never thought to have checking the DRO mounting for continued security. Will need to do so now and then. This chain (on the edge of working the Ti and the DRO looseness) took me like just 1 step from the brilliant sharf actually creating a problem. Gotta keep the shop neater. And I learned that Ti sharf can be ignited by the burning Ti. At the sharf density/surface area/air flow I happened to have it was not any chain reaction, but it did ignite. Ti is not a normal material. Not sure I really want to work with it. Maybe finish my little project and then leave it to the pros.
And check my DRO mounting now and then.
Amazing hobby.
-Bill
Amazing hobby.
-Bill
