- Sep 29, 2014
- 2,102
Nasty turning job on Wed., 10 1/2" Dia. plastic bead impeller for a large scale injection molder, 304 stainless weldment.
Turning the bearing journals at 350 rpm's turned it into an excellent fan, facing the vane ends was a testament to the Sandvik SS interrupted cut inserts which worked flawlessly considering the conditions, I faced it at 90 Rpm's and it still sounded like a train wreck.
Safety First, I stood 5 feet away when it was running.
Some .001" shim material was required in the center to reduce the run out, this can be a maddening process at best.
