- Oct 30, 2013
- 83
I recently acquired a power hacksaw; one that I didn’t need, and too old. But, I was intrigued by its design so I thought I would look into it further. This saw was manufactured by T & S Engineering of Pasadena, CA. I tried all the search engines I know but no joy on any links or information - let alone the coveted operating manual.
I’ll start with some pics and the information I have: it may end up as two posts.
This is the name plate on the saw base.
This is part of the ratcheting system that is behind the walking beam attachment. The dovetails are on the right and left
The walking beam is on the right (these pics are before cleanup), the screw in the foreground holds the top rail that the rope bearings (2) ride on. The “mast” that the dovetails ride on is on the left . There are 4 Allen head screws (the bottom one is broken off) that adjust the gib against the dove tail above
This is the complete ratcheting system that allows the saw to “fall” as the saw cuts
Another view of the ratcheting system with the gib for the dovetail at upper right that is made of brass
The back of the saw after cleanup. The vise is part of the pan casting. The yellow clamp is canted to clear the circular handle from the saw frame (also yellow) AND creates a lever against the material being sawn. The orange topped handle is the cam and lever that raises and lowers the saw on the mast.
The mast is in blue
This is the front of the saw with the solid brass walking beam in the middle of the pic, and the eccentric lever (orange cam) which uses a bicycle chain to connect the ratchet housing (pictured above) to the cam. Lift the lever and swing it over the top of the cam, and the whole saw is lifted to allow the material to be placed in the vise.
This is the saw lifted to the top. the eccentric handle is now "over the top" and the saw is fully lifted . I am waiting on a saw blade from Daily Saw to mount on the frame (an odd size of 15.6" hole to hole) which is fixed in length.
This shows the saw frame with the rope pulley bearings riding on the the round shaft. There are two sets of bearings and two rails, one on top and one underneath the frame. This locks the frame to the mast and gives it the sliding motion in a straight line. With the amount of work this saw has seen, the bearings, rails ( or shaft), and dovetails all seem to be in great shape.
What is not obvious is the mast SWIVILS about 60 degrees in one direction. This is not an easy feature to apply so those of you with an ELLIS band saw can rest easy. What is also not shown is the cooling oil distribution system ( the motor and pump below the saw drive motor). The pan is cast iron with a sump underneath the mast (this allows the mast bolts room to swing). All the collent is collected in this sump and then pumped back out to the flex tube shown two pictures above.
If anyone has any information on this saw, please let me know. I probably wont keep it, but i still would like to know more about it. I have never seen a saw like this one, and on top of it, it is very well designed, unique to me.
The mast is in blue
