The Only Burke #2 On The Interwebs
Cooter Brown
863 Bronze
Nov 23, 2017
1,191
I bought this machine on eBay in Ohio early 2017 for $350. It has the biggest 2HP 3PH motor I have ever seen, the motor runs great but I can't get it to run slower than 1400 RPM, the pin spanner nuts on the spindle and the clutch won't turn. So I can't get the machine to run slowly enough to run high speed steel tooling.
Does anyone have any ideas for removing those pin spanner nuts?
Thank you
20170514_062239.jpg20170514_062326.jpg20170514_061954.jpg20170514_062347.jpgOffice Lens 20170514-062432.jpg
None of that works. I'm thinking of making a spanner wrench that goes on an impact gun.
Assuming the problem is corrosion, I have run into situations where PB Blaster (my preferred loose juice) won't get it done. In all of these cases (so far...) a homebrew of 50/50 Automatic Transmission Fluid and Acetone has worked wonders. Soak it good, let it sit, repeat two or three times over 24 hours and then some vibration/impact may do the trick.
If you have a wrench that fits them you could try this tip from AvE.
He cuts off an impact hammer chisel and grooves it to use on the side of a wrench.
Please keep us updated of how it's going!
-brino
I have all the penetrating oils, but after a lot of frozen stuff, my go to choices for tough jobs are 50/50 atf/acetone, and Kroil.
I'm almost just thinking about giving up on the pulley swap and just getting a VFD it's only a 2HP motor, about $250 VFD.
I have tried all of that but I cant get anything other than motor nut to turn...
