The last cutoff/parting tool I'll ever buy?
juiceclone
Oct 24, 2014
208
This may be the last parting/cutoff tool I will ever have to buy.
Not elegant or complicated but it works.
I got a 4 in “plate joiner saw blade” from Harbor Freight for $10 bucks and a ¾-16 x 4in bolt and nut from a hardware store for another sawbuck. The .750 bolt fits my AXA QC tool post boring bar holder correctly, and I cut an .875 x .093 shoulder in the head of the bolt …. (needs to be slightly less than the thickness of whatever blade you use) The HF blade has 6 carbide cutters aprox .140 thick so that’s the width of the cut. I ground two of the carbide tips to have a flat cut, and one of those I thinned to the thickness of the blade, approx .110. I drilled and tapped an index pin hole in my boring bar tool holder (the only change to that) and drilled 6 index holes in the blade so it can’t turn when cutting. I did find this necessary because I tried a prototype without and under heavy load it would shift down. Of course that could be a plus because it will stop cutting if you go in too fast :>)) I can see that in a deep cut I might have a problem with chip blockage, but I can always grind clearance deep on one spot for that. This thing is SOLID. All that metal above and below the actual cut point does not flex, particularly from side to side as I have seen in all other cutoff/parting tools . It seems to be flexing down the entire cross/compound on my Chinese lathe when I push it too much.. There are other blades available everywhere that could be thinner and ?better? suited to this. Most of them have many more teeth some of which would probably need to be ground off to be suitable. I got this idea from another? Forum somewhere where the guy ground part of a blade to fit his cutoff blade holder.parts.jpg bolt.jpg assembled.jpg mounted.jpg cutting.jpg blade.jpg index pin.jpg
That is one of the most interesting ways of making a parting tool that I have ever seen. I'm going to have to build one.
Great Idea....next trip to HF I will pick up a cutter.
$10 for 6 cut off blades in one is not a bad deal at all.
Nicely done. Will have to give that a try. Thanks for posting. Mike
That may be the last cut off tool I ever need to buy as well :)
I love it.
Very nice, I too will put it on my to-do list. Question: If you drilled holes in the blade, then it must not be hardened, right?
Greg
Greg
it wasn't hardened, but fairly tough stuff ...three sharpenings of the drill to get six holes .... the outside surface seemed to be harder to drill ....once you were in it drilled pretty good till the other side..lots of coolant/lube
