Ok, so I picked up an older 4x6 bandsaw recently. I've since been trying to get it to cut square vertically for the past couple of weeks.
The issue is it does not seem to cut consistently. I've been cutting wood for testing as recommended by John Pitkin and one cut will be semi-straight, then without adjusting anything, the next cut will be totally different. Sometimes it will even wander through the cut making a curved cut...
Things I have done:
-I've read through the write up about checking the swing/drop for square to table and that seems good.
-I put a brand new 10/14 blade on it.
-Squared up the vice, cuts laser square horizontally.
-Tensioned the blade properly (as tight as I can get it with one hand)
-This one has the adjustable bearing guides so I've
-Adjusted the side guides so they are pretty snug but can still turn the bearings by hand as recommended by the write up by John Pitkin and others.
-Machined the bolt slot for more clearance for angular adjustment.
-Adjusted the twist of the upper and lower guides about 9 million times cutting a test piece every time.
I would appreciate any help, I know some people have great luck with these little saws.
Things I have done:
