- Mar 25, 2018
- 131
I'm chasing noises in my recently delivered 1127VF-LB. That required opening up the gearbox. The mystery noise does not originate therein; but I did see how the machine does its magic. Reminded me of a four speed tranny with wide gear spacing ....
Anyhow, long as I was in there, I took a pic to share with those who may wonder what's behind the cover. I was impressed with the cleanliness of the interior of the gearbox. Not a bit of swarf anywhere.
Going a bit deeper, I got inside the headstock. Found the source of the noise - bearing at the input side of the spindle shaft. But there's no decernable play and it runs true so I won't be premature in affecting a decision to replace it just yet. I did find that the speed control circuit board which is housed in the same area was contaminated with what appeared to be silver colored metal dust (perhaps the residue of a drilling operation) and because electronic circuits don't like that kind of stuff I did a compressed air cleanup.
UPDATE:
(For those who may need to remove and replace the gearbox cover for future maintenance)
Putting everything back in place requires a bit of adroit manipulation that would have been easier if I had four hands. Setting the feed direction, feed rate and feed/thread gears in their neutral positions and then "eyeballing" the alignment of the operating levers to mesh with the correct gear set worked best for me. I made a wooden block to just fit between the bottom of the gearbox and the tray and slipped it into place to support the cover whilst tipping the cover into place.
UPDATE:
