- Jan 14, 2016
- 86
I told myself when getting into this craft that I wasn’t getting into any of the restoration. Well that was all good until a few days ago when my wife says there is this add on a local facebook yard sale for a hobby lathe a guy wanted $150 for. To make a long story short it turned out to be an Atlas Clausing 10100.
s it turns out it’s in a little rough shape. The ways look pretty good but every thing is just gummed up with old grease. The carriage and lead screw were bound up at least they would move under duress. The half nut wouldn’t budge. With copious amounts of carb cleaner applied to all the gears and screw I got it to work and seems ok but every thing needs more cleaning. Well I knew I should have given it a better cleaning before trying any thing but no I had to see if it would run. Not a good idea, apparently the tumbler gears for the lead screw direction selector were still bound up. Well as you might have guessed one of the gears and the selection lever broke. I have been able to find the gears on ebay and a couple other places. Does anyone know if the selection assembly fro a 618 would inter change I see one of those too. Question about Zamak I have been reading a recent post on it and think well pretty sure the gears are but from what I’ve been reading the head stock is too. So can Zamak be repaired , weld or brazed or some other obscure method?
