Whatever works, works. Whatever does not work, you will probably need to live with unless it is just a damaged wire connection. If you are an electronics geek, you might be able to troubleshoot some issues on the old circuit boards. I doubt if anyone does that commercially, and it may not be worth the effort and investment. Often the existing scales, if they work, will also work on another readout. Others here may be able to help you with specific issues...
