- Dec 30, 2018
- 73
A few weeks ago I got a small surface plate and a set of gauge blocks. I needed a better test indicator stand.
Today I completed this:
Made during the C19 lockdown in South Africa.
Bright mild steel, Aluminium, Brass, Delrin, Kydex and HSS for the shaft. Basically whatever I had lying around.
Machining done on my Mini Mill and Lathe, steel surfaces and bevels ground freehand on a cheap bench grinder.
