My experience is that stands for light aircraft engines hold the engine in a vertical position. Your post mentions "all position" so are you thinking of an automotive type of horizontal rotating stand? I have seen where home builders have fashioned a horizontal stand by adapting a common automotive engine stand so that it will accommodate the aircraft style of mount. The problem I see is that a lot of work on smaller engines (say 100-250 HP) is on the back of the engine: magnetos, vacuum pumps, generators, starters, etc. The automotive style of stand greatly restricts access to this part of the engine. The vertical version leaves this area wide open, (but you may have to stand on a step stool.)
I believe that the engine manufacturers all caution not to support the engine by the prop flange in a horizontal position. If you are going to work on the engine in a horizontal position, it needs to be supported by the engine mounts.
The typical aircraft engine overhaul stand looks like a heavy duty tripod with a flat surface on the top which is bored and drilled to dock with the propeller flange on the engine crank. The engine is held in a vertical position. It is pretty easy for such a stand to accommodate a number of engine sizes because it is easy to adapt to the various bolt circle patterns on different engines. This type of stand is used for major tear downs and rebuilds since it the crank is mounted to the stand and the engine is assembled around the crank. TC gasoline engines (as well as the competition) have a split crankcase which has to be assembled around the crank. The rods are mounted to the crank before the case is assembled, so you have to be able to reliably support the crank during the early stages of assembly. Aircraft Spruce sells one that will fit both TC and Lycoming engines.
http://www.aircraftspruce.com/catalog/topages/enginestand.php Here is a link to a well documented home design and build, along with some mounting dimensions
http://cootlog.net/?p=107 I am sure there are others. Try a Google search or look through an issue of Trade-A-Plane.
I recommend that you get the requester to define exactly what they are trying to do, and which engine sizes need to be accommodated. If they want a horizontal version, I think you want to make sure they understand the issues before you go ahead.
Terry S.
