- Jul 12, 2015
- 330
I currently have this slide arrangement for adjusting the track tension of my rover project. I'm sure you will agree it's not the most elegant solution. It worked fine for proof of principle, but I think tee slots may be better for this application? The socket head cap screws are 5/16 so I began the search to find a suitable tee slot cutter. It appears the smallest shank diameter available is 1/2". I have a small Taig milling machine with ER16 collets which only go up to 3/8. Do you guys have any ideas for a better solution? My guess is the high cutting forces dictate the need for a thicker shank. Do you think I could turn one of these down to a 3/8 shank? Thanks in advance for your help.
