- Dec 28, 2021
- 5
Hi all,
I am probably going to buy the TDA420. My mill (King Rich KR-V2000) is sort of up and running. I have re-fitted the Accu-Rite-II (x/y) and Newall Microsyn (z) that it came with.
Along the way I broke the Y axis AccuRite scale so replaced with a Ditron one, but I used the old AccuRite cable to make an adapter, so I still have the DB9 ready for when I swap the DRO itself.
Anyway waffling aside, what's the likelihood of some hardware changes or new versions coming out from Touch DRO ? Given that there's a chance it will sit in a box for at least 6 months, should I wait a bit, or just get my order for a TDA420 in? It's going to come out relatively expensive after VAT, duty, international shipping etc. (do you need an agent?... I have space for a few boxes of stock)
Secondly, I believe I read in the past that support for the non-TTL Microsyn heads doesn't exist, and isn't likely to exist. Unfortunately mine is non-TTL. Should I just forget about it and buy another Ditron for the Y-axis? It seems such a shame because that scale is a thing of beauty and simplicity. I did some googling but I'm not seeing any simple electronics projects to build your own converter or anything.
