- Oct 29, 2012
- 1,392
A guy I know, well he's a real big idiot. He knows better than to weld on pressure vessels but in a moment of weakness he convinced himself it would be alright just this once, so he drilled a hole in his air compressor tank. Then he stood back and looked at it, and knew that he had made a mistake.
I was doing some math. A 3/4" NPT fitting has a radius of 0.5".
Pi*r^2 * 150PSI, that's 117 lbs of force on the fitting, pushing it outwards.
That's not really a lot, but I think the concern with welding it, isn't that your weld will fail, but that the heat you introduce while welding will un-do the heat treatment of the tank, and the tank itself will fail (explode).
So, what if you just don't introduce any heat?
What if a guy (an idiot) were to just tap that hole he already drilled, with a 3/4" NPT tap, and screw a fitting into it?
I think (please correct me if I'm wrong) then the only risk is that of the fitting being violently ejected from the tank at high pressure, which is less unsafe than the risk of the tank rupturing.
The fitting could be built up around the protruding area with some of that "steel putty" stuff to distribute any side load that might be experienced from pulling on the fitting, and hopefully mitigate some of the risk of the fitting being ejected. Then the tank could be positioned with that untrustworthy fitting pointed in a "safe" direction, like the back corner of the shop, where if it ever does turn into a projectile it can only kill some old scrap pallet wood.
Does that sound like a less than 100% stupid solution?
