- Dec 25, 2011
- 10,552
Recently, someone on the Yahoo Atlas 618 list started a brief discussion about how you oil the cross-feed screw bearing by commenting on losing the screw plug for the oil hole. Someone else said that his (assumed to be early) 618 carriage did not have the hole. I did some research and found that only the earliest (that we have) 618 parts list, which is of the style where all the parts are laid out on a table and photographed, didn't show a hole in the top front of the carriage and did seem to show the threads on the M6-46 bearing as running right up to the shoulder. All of the variants of the 101.07301 parts manuals have a line drawing instead of a photograph of all of the parts laid out as if on a table. The drawing of the carriage is a front view, so no clue there. The drawing of the bearing is an isometric and doesn't show a thread relief although the similar drawing of the M6-47 Tumbler Gear Stud does. The lube chart for the 10D calls for removing the screw in order to oil the cross-feed screw bearing. And the parts lists and lube charts for all of the mills show the screw plugs and/or their location..
So despite the fact that neither the carriage nor the bearing part numbers ever got a Revision A suffix, I had to conclude that the very early 6" machines didn't have the oil hole.
Then the person who had said that his carriage didn't have the hole came back and reported that after a thorough cleaning of the top of the carriage dovetail, he had found the screw.
So my question to put the matter to rest is this:
Does anyone actually have any size (6", 9", 10" or 12") or model of Atlas or Atlas/Craftsman lathe with a carriage that is missing the tapped hole for oiling the cross-feed bearing? If present, it will be on top of the dovetail flat near the front.
Edit - 9" owners are requested to respond whether you machine does or doesn't have the oil hole.
