I have a hand-me-down Emco MAXIMAT V13 that came with the MAXIMAT taper turning attachment. I am learning the machine and I would like to figure out how to setup the taper turning attachment but I have no manuals, drawings, diagrams or even photographs to reference. I've searched Google and Bing without any real luck. I did find some attachments for other lathes that are similar enough to start to give me a hint.
Outstanding questions
Photo 1: Still on the bench
Photo 2: Installed on the lathe
Photo 3: Installed on the lathe close up showing setup for 8 degree cut
Photo 4: Tool holder height?
- The attachment attaches to the cross slide. Is it suppose to attach to the back of the cross slide (away from the operator) as in photo #2?
- It appears that the tool holder holds the tool way too high compared to the rotational axis of the work as in photo#4. What am I doing wrong?
- I have an Aloris BXA tool post holder on my cross-slide. If I purchased another Aloris BXA can I get it to work with the taper turning attachment considering the tool height issue in photo #4?
- Does anyone have a manual for the Emco MAXIMAT V13 taper turning attachment?
