I've never used Taper Lock Bushings. I have some coming, so I can't inspect them yet to see how they are fixed to a shaft. In my case, I'm using it on a motor which has a straight shaft with a key and I'm ALSO using the taper lock bushing on my mill's spindle which doesn't have standard key cuts.
Basically my question is, does the taper lock bushing somehow pinch down with a thru bolt. I see a slit in the bushing but since I don't have the bushings yet, I can't tell how it clamps onto a shaft, if in fact it does ? Do I need to drill and tap a hole for a set screw to lock the key in ?
for reference here is a picture of the one I bought :
Thanks for any help,
Jake
Jake
