- May 27, 2016
- 3,479
Yes - I have been here before, in a way, and I am promising myself to I will eventually be making my own tap wrench. There are lots of good examples, like the one from This Old Tony, and the reproduction Starret from Brandon Sander (Inheritance Machining). Right now, I am in what Brandon would call "nested side projects", so I have been surviving on the kind of cheapo kit that comes in the flimsy metal box with the "set of taps". I did purchase two supposedly "better" types, meaning the cylindrical kind as shown in the picture, that being the "bigger" one. It might even prove to be a bit better, if it would open up far enough for me to find out! The other one came out the taps set box.
The hardened bit measures 9.99mm The slot it slides in measures 10.64mm. For the non-metric among us, that is more than 0.025" of slop. Threads are coarse, and there is only hard steel up to the tap, so I don't expect it will be able to "tighten", but this one lets the handle fall off every time I let go to grab again after a 180° turn. Somehow, that handle loosens itself, by itself, and if the tap is not already part-way up a hole, it will just drop out of the wrench!
I am tapping for stainless thread inserts into the 1/4" thick aluminium angle bracket to take M8 bolts, so the tap for the inserts looks like M10. I always use inserts into aluminium. How is this "nested"? It's for my super-strong trolley with 10" wheels, and a steering arrangement in the front that does not have a central pivot guaranteed to allow the whole thing to tip over. It has to move my mill, and other machines. I already mis-spent £120 on an allegedly "strong" trolley rated (they say) to 350kg (770lb) that turned out totally unusable to entrust my machines on. Mine homebrew version is made of ply and 2 x 4(s), and has a Ackermann steering link so the front wheels can stay where they need to be. Unfortunately, the critical bits do need some M8 bolts.
