- Jun 17, 2011
- 2,069
I use my tangential toolholder on the 9" lathe so much that I had to make one to fit the big Storebro lathe.
I opted for a 5/16" HSS cutter, so I used a 1/4" endmill to cut the groove. It's set at 12[SUP]o[/SUP] left and 12[SUP]o[/SUP] forward. When I first got into this hobby, I assumed that if you wanted a 5/16" groove, you would use a 5/16" endmill. If you do, you get a sloppy, oversized groove as the bit pulls off to one side. By cutting a narrower groove down the middle and then cutting to the line on each side, you get a truer groove with more control.
A perfect slip fit.
When I made the first tangential, I also made a fixture to grind the cutter to the required 30* angle.
A double counterbore to make room for the clamp.
You can see the 12[SUP]o[/SUP] x 12[SUP]o[/SUP] angles on the cutter.
I borrowed the idea from another forum to blast the holder with crushed glass. Gives it a nice finish.
Tangential toolholders do a great job in both turning and facing operations.
A perfect slip fit.
