- Dec 27, 2014
- 4,093
I have a Clausing 3950, branded ATLAS lathe, its a 6 by 24. It is very nearly new, not used before I got it. When I got it the screw to advance the tailstock moved smoothly. I've been using it off and on for a couple of months now, and the screw is progressively getting stiffer, not consistent, but twice every rev it tightens up then releases, it goes steady by jerks, and the jerks are getting worse.
I've had it apart, don't see any problems except I can't run a tap in it, left hand don't you know.
I'm open for suggestions, comments, anything that you think might help.
