I have noticed two things with my tailstock. I cannot retracted the shaft to 0 without disengaging the morse taper, it begins to kick out around the 0.50" mark. Is this a setting or something internally I need to fix?
The other issue I noticed with using a drill bit in a jacobs chuck, the tailstock shaft appeared to be lunging forward instead of moving forward steadily under pressure. Basically I could see it jump.
Any ideas on what is going on? Or is this normal?
