- Aug 13, 2020
- 1,342
The tailstock on my Craftsman Commercial 12x36 is hard to slide back and forth. It seems to bind up, and I have to make two or three turns on the clamp bolt to get it to slide. It gets very frustrating, especially when trying to drill a deep hole.
Is this a known problem with Atlas lathes?
Is there a recommended solution?
I know that the tailstock/lathe bed is worn a bit. The nose of the tailstock droops about .002", which I've corrected a bit with a shim between the bottom and top half of the tailstock. So, I'm assuming the wear has something to do with the binding.
