- Sep 28, 2013
- 4,392
this turned out to be a bit of a drama as with most things I make. Still, it only took me a week, so it went pretty fast Not really sure it deserves its own thread, but I took a bunch of pictures, so I might as well use them!
Aim - new 1/2-20 threaded arbor for my mystery lathe's mystery tail stock taper, so I can fit a 1/2in drill chuck for those larger holes that my current 3/8 drill chuck can't handle
Scrap stub axle, with honorary locked up bearing still in place
hacksawed down to about the right size
trued up in the 4 jaw after turning down the to be threaded stub. This takes a while as there's so much flex in the headstock (>15thou by hand pressure!) that I have to be careful not to misread the DI.
artsy pics of the lathe "hogging" off 0.45mm at a time
taper turned (lots of time with sharpie in one hand and tail stock in the other). 8-32 bolt in the end is to finely adjust the ejection of the arbor. Works really well!
cutting the wrench slots on the "mill" to stop the arbor spinning in the tail stock
After I completely mangled cutting the threads with a die, I finally got the chuck to snug up against the register. Run out isn't great, but it's tolerable and the chuck is a resurrected Jacobs that appears solidly beat upon, so it's probably better than expected!
