Hanging about getting a larger Galaxy Tab for the lathe and the mill. What have you used for tablet holders that have held up to a shop type environment? I'm almost certain if I go and buy something cheap off amazon, I'll destroy it within a week.
Does that hold the tablet in portrit mode too? Looks like it might not constrain it from slipping out the bottom if you rotate it, if it even rotates?I purchased this and it seems to work good. The Ram Mounts are also excellent but more expensive.
You mean rotate by taking the tablet out and re-mounting it the other way? I think for this to be a useful feature, unless you're going to just leave it one way or the other, for switching back and forth I'd want a holder that has the rotation built in.It does rotate and the arms will also stretch enough to hold my tablet (9.5") in portrait also. My tablet would be a problem though as the power connector would be in the way of mounting it like that.
