- Dec 27, 2014
- 4,093
As most of you know, I moved to Holland a couple of years ago and set up a small wood shop, hobby level. Among tools I purchased a new HBM 10" table saw.
It's been OK, nothing to write home about, does the job. However, recently it has been getting harder to crank the blade up. Down no problem, almost spin the handle. Up, on the other hand... well it got to taking two hands. I looked inside and found a pair of nylon bevel gears supported on one end only (and not really secure) turning a small, possibly 10 mm screw for raising and lowering the table. I guessed it had dust on it ( can't really see anything under there) and eventually decided that oil would help, if only until it got gummy. It is now one hand operable, but won't spin, as it will in lowering the blade.
Problem: If I get another saw, will I have the same problem? and how can I tell. I was discussing this with my partner and she suggested asking you guys (and gals) if there was information out there on this problem.
So here we go...
Is there a cure? perhaps a different lubricant (but how to apply it?)
is there a saw recommended that doesn't have this problem (my 50 year old Sears saw (left in Ohio) didn't have the problem)
Other suggestions?
So here we go...
Other suggestions?
