JonJust be weary that since you are replacing an "original" powerfeed (whether it is the gear driven, 6F, or 8F) that the only brand I know that makes the proper kit to adapt a power feed to your table and lead screw is Servo.
Also, what is going on with your powerfeed that you want to replace it?
Jon
The feed worked when I got the mill about 2 months ago, although the speed control was not consistent. I have the wiring diagram for the mill that has the control wiring from the board in the main electrical panel to the limit switches and the motor. What I can't find is any schematics for the board itself.Rarely do those pots go bad. Do you have a wiring diagram for it? If not, let me know and I can get you a wiring diagram for this so you can ensure you have it all hooked up right.
Did you receive this not working or was it working and then died on you?
Jon
