A few months ago I picked up an old Cincinnati vertical mill. I have it up and running, and I now want to buy a clamp kit. I measured the T-slots on my table and got these numbers:
Width at top of T-slot: .5580" - this is just slightly less than 9/16"
Width at bottom of T-slot: .9665 - this comes out to about 31/32"
There are three sets I am looking at from Enco.
1/2" Slot size, 3/8" studs:
http://www.use-enco.com/CGI/INSRIT?PMAKA=400-2501&PMPXNO=951285&PARTPG=INLMK32
9/16" Slot size, 3/8" studs:
http://www.use-enco.com/CGI/INSRIT?PMAKA=240-7207&PMPXNO=949786&PARTPG=INLMK32
9/16" Slot size, 1/2" studs:
http://www.use-enco.com/CGI/INSRIT?PMAKA=400-2562&PMPXNO=1645538&PARTPG=INLMK32
Which one should I buy? From what I can tell, my T-slots measure slightly less than 9/16" - does that mean I can only use the 1/2" Slot, 3/8" stud set? That makes sense to me, but I want to make sure. After all, a wood 2x4 does not measure 2" x 4". Maybe there's some sort of "nominal" T-slot measurement system that I'm not aware of.
