Beginner's beginner back again, so be gentle. I've had my new Grizzly G0619 for a couple of months now. The head seems to move up and down the column "extremely" freely to the point where it will almost move down on its own if you crank it down quickly. But to this point I have not taken a look at tightening the z-axis gib. However, yesterday I finished installing the z-axis DRO and now when I tighten down the head, I can see on the DRO that there is a lot of movement measured on the DRO display. I had the same issue on the X and Y axis, and snugging up the gibs a bit nearly eliminated the movement on the DRO reading when I lock them down now. I was hoping for the same effect on the z-axis. So here is the question. How do you adjust the gib on the z-axis of a G0619 (SX3)? The gib is bounded on the top and bottom by very large flat headed adjustment screws and I thought to would be a good idea to ask how they work before taking a chance at messing them up like I did with when I tried to remove the backlash from the x-axis. I would appreciate hearing about people's experience on this.
Thanks in advance.
Thanks in advance.
