Surface Gauges
Nelson
Site Founder
Administrator
Sep 22, 2010
7,220
There are several surface gauges for sale on Ebay- Starrett and other nice brands- so I was of course wondering- is this something I need for my home shop?
If so, what is it really good for in the home shop context?
Thanks,
Nelson
I've never really found a use for them in my career. I'm sure there are places that it would be helpful, and I do have one (or two??), but it's not been any help to me in what I do. I can see it used in patternmaking, modeling, and things that require a bit of comparative layout work. Maybe when I get started in my clockmaking play, I'll find a use.
Having no idea what you already have, I couldn't say whether or not there might be more useful tools, or more immediate needs that you have.
Doesn't sound like something I really need- they are going for like $25 so i thought to consider it, but, I probably would be better off getting a depth mic or something else I can use.
Thanks,
Nelson
Here's a picture of my surface gauge.
I picked up a bar of cast iron at the scrappers a week or two ago. I got it to make the sliders for a taper attachment, but I figured I'd use the shaper to make the base for a nice-looking surface gauge. It's amazing how long it takes to cut this stuff when you slow the bandsaw down to 96 SFM.
About the only place I've use my surface gage is to indicate/align parts on the mill. Back when I had my Reed Prentic No. 5 vertical mill, I use my large surface gage quite often for setting up and indicating parts in for milling.
Also used them on the surface plate to check runout on round parts/shafts.
If you have a height gauge you don't need a surface gauge. Otherwise, they are used for layout and are handy for holding an indicator on the surface plate or machine table. I think I might have one...somewhere.
Tom
I used my old starret Surface gauge (SG) this afternoon for two things.
First I centered the cutting height by getting the height of a dead center with the SG and then transferring that to the cutting tool. SImple and quick.
Second I was mounting the casting for my stuart steam engine in a 4 jaw. You have a rough cast exterior that you center it to. No way I am going to put the "last word" on the rough cast. So I used the SG and eyeballed it against the outside edge of the casting. Worked great.
I love the old tools with patina.
Surface gauge or paperweight ?
Yes, a surface gage is a carry over from the early days of the trade.
We can still find some uses for it but for the most part we adapt it to a modern use, mostly for indicating and rough checks for a setup in progress. Can be handy for quick setting when checking and layout things.
However a height gage is the way to go if you are after accuracy.
Jerry
