- Mar 12, 2012
- 262
A while back while turning some hard chrome shaft I posted about the bore finish being rough. That project didn't require a smooth finish so I chalked it up to the material being very hard. This project reuires some 2" OD aluminum with an internal thread of 27mm. I chucked up my 2.100 stock and centered it within .001. Then proceeded to take some off the outside to true it up. About .050 with the intent of leaving it at 2.100 finish dimension. i had taken off .025 or so and noticed that my finish was far from smooth. Tried light cuts down to .001 per pass and it just isn't smoothing. Being new I tried some faster and slower speeds and using the auto feed vs hand feed. All leave about the same results. I am using a carbide cutter and did try a different one of those as well. Checked my gib adjustments on both the saddle and compound slides. Both are on the verge of being overtight. I have attached a picture though it may not make it clear the roughness that is there. What am I missing?
