Supermax Way Wipers
dlane
Sep 27, 2014
3,123
any one know if BP mill way wipers would work on a 1986 Supermax yci 1 1/2 mill ?.
And for that matter other parts interchangeability between the two
Guess not, if someone wanted to make them what would be the best way to go about it , material?.
I don't know about BP wipers, but Kent KTM-3S parts should all interchange, exactly the same machine. http://www.kentusa.com/ They have a good parts department.
If I were going to make some, I would use 1/8 inch neoprene gasket material.
What did you figure out. I recently am faced with the same issue??
After removing , cleaning deburing the wipers I decided they were still good and working ok.
When they get wornout I'll go with Kent ktm3s wipers
Thanks. I was thinking about putting felt behind mine after deburring and cleaning them. Thanks again
