Summit model 19-4 19x60" resurrecting
Zyox Jägergeist
Jun 11, 2019
84
Hello! Pretty new to the forum but id figure I should share one of the machines I am currently putting some life back into.
As the title says, its and older summit. bought from the machine shop I work at and had been used hard for about 20 years, until it was in need of a few repairs.. and with their growing number of cnc lathes, aswell as having two manual lathes this one just got set in a corner and never fixed
2018 they put up a new building, moved and cleared out all of there manual/broken machines (mwahahaha bought em all!)
I bought this lathe knowing it was abused, didn't really know the extent.
So now that the backstory is told onto the work in progress, here is a list to sum it up
-Wore out forward clutch
-all new bearing needed in the carriage aswell as a worm set for the X power feed (the carriage sat for many years with no oil,... just water from coolant. gears where seized and bearings where locking it up even worse)
-new bearing for the tailstock handle
And a few pics of the lathe, and what the carriage looked like when we first got it off.
I had some spare time at work with the mill I run.... so I figured id make some tool holders since I didn't have any!!
Started off with a block of qt-100 on the bandsaw, then moved to milling it square... followed by more milling and more milling... then a bit of tapping and testing!
I still need to turn the thing for the height adjustment I just have a gold grade 8 bolt in there for now... but the body is done, made it to fit a 1.5" insert holder :)
I know my lathe sat for long time and someone got their hands in it but the more I see yours the more I think mine barely had any use. Clearly this was after cleaning but I didn't have to do much. This is from the inside of my apron gearbox.
Your lathe is pretty much brand new, paint isn't even wore off of the rpm wheel yet :)
My lathe probably has 10000-20000 hours on it. (we have lathes clocked at 56000hours in our shop) 90% of the bearings in my apron where toast, same with the bronze worm set but i have everything stripped apart and the new bearings come in! 297875
there was literally nothing left of the needle bearings, just the needles! and the middle of the ball bearing was nearly ready to fall out! xD
Speaking of it,... does the manual have a part number for that bronze gear?
Got some more time to clean the carriage up, wash, sand and paint it. the casting is pretty rough so I didn't get any crazy ocd with the paint lol looks a ton better then it did!!
pics where mostly before I took all the tape of and sanded some surfaces whoops... waiting on a few more seals and bearings now. need to order a book and buy a new gear or two!
Wew, been a while! and im sorry to say I have not been working on the Summit, but I have been working on nearly all the other machines I own lol!
Made a quick video of a Mechanicy universal mill I saved from the scrapyard, here it is~
A bit of backstory if you wish to read it! (similar to the intro of this thread)
Couple years ago the machine shop i work at was moving to a new building. because of this they were getting rid of the machines they broke and never bothered fixing. they were not fixed because of the more and more cnc the shop was aquiring. out with the old in with the new.
The 316tf K&T went for scrap, they run it out of oil and it ate most of the feed gears.
The mechanicy Fwa41m had clutch problems, oiler problems the rpm and feedrate would not change finally the spindle locked up.
The Summit 19-4 had wore out clutch and apron, as you may already know
Now, The mechanicy was one mill I trained on, I had a special liking for this one, it was referred to in the shop as "The heavy mill" it was and still is tough as nails. She run threw unholy cuts all day and just took it, even tho it was never taken care of.
Built in 1976, weighing in at 10950lbs she was a decently sized girl. Firstly the feedrates stopped working, we run it in one feed, then the rpm selection stopped, we run her in one feed and one rpm selection, the auto way oiler stopped, we run her. the case leaked out most of the oil, we run her, it ate the electrical brushes that engauge the clutch, and finally, the spindle locked up, she was put out of service.
I got the two mills for free and brought them home, they sat under a tarp for the winter, sumps frozen. come spring we plucked the mill from the flat bed, put her on a pad and built a shop around the mechanicy, she still was broke, I did not exactly know the extent but we pulled her apart many times fixing one thing after another, the spindle locked up due to a couple lock nuts loosening off the main drive shaft and jamming the gears, easy fix.
The rpm changer stopped working due to various misalignments, corrected those
The feedrate's not working were caused by a sheared off key, made a new key
We replaced the clutch brushes
After a bit of fighting and taking things on and off she come alive, one thing at a time, this, that. After more fighting we finally managed to get the spindle to turn on, it was a happy day, the mill was saved.
Sounds like you've been a busy man! Thank you You again for all the help with my summit!
I look forward to seeing your progress as time goes by.
Sent from my SM-G960U using Tapatalk
Aye, very busy... hard to find the time to get to everything and not burn out haha.
And I was more then happy to help! That 19-4 is a good tough lathe.
Ill have to get around to mine soon, I saw you moved aswell! wow! thats a big move, hope the new place is awesome!
Heyo! Its been to long again. Ive been working on the summit, finally got my 19-4 manual but found out it was a waste of time, money and I have to make the parts anyway.
Either way I finished making new blade guide holders for my forte 250 bandsaw. the old ones were cast iron and looked like they were broken and repaired about 5 times, didn't hold the blade strait at all anymore.
The steel I used is just C1018, nothing crazy fancy. just something that will last.
The saw was left out in a field, for a unknown amount of time. It needed allot of work to get her to cut again, all new electrical etc.
Quick video here of machining them.
Then some pics :)
