John,
Please post some pictures of the insides of your mill. I also need to tear apart my RF-45 clone to fix a leak and I'd sure like to see what I'm up against.
Thanks,
Ed
Edit: I forgot to say that I used kerosene for cleaning out my lathe and mill gear boxes.
Ed, I'm sorry to say that I did not read your post in time and my mill is back together. She works, is leak free, and seems to work a bit better with more spindle bearing preload)
Disassembly is no great shakes when you know ahead of time what's in there (I didn't). Basically it goes like this for seal replacement:
0) Drain gearbox.
1) Remove Motor
2) Remove snap ring on spindle bearing (on top). Not sure you really need to do this... I did.
3) Remove gear selection knobs
4) Remove front panel
5) Remove power switch (if equipped on side of mil like my Precision Matthews).
6) Remove six cover screws
7) Remove cover, some of the gear shafts may come off with the cover. Reinstall them into the bottom of the gearbox when the time comes.
8) If equipped with power down feed, remove power down feed on/off knob. If not go to step 11
9) Remove two screws on outside of housing holding the cam wheel shaft for PDF engane/disenage.
10) Remove power down feed driven gear.
11) Now you can get at the seal holder. Remove the three screws that hold it on.
12) Remove and replace seals (see below)
13) Flush the gunk out with mineral spirits.
13) Check spindle bearings and readjust preload if required (I set 'em a bit tighter). There is a tanged lock washer under the preload nut. I just reused it. Be sure to lap the bottom of the preload nut as it burrs up really easy. Now is the ideal time to repack the spindle bearings (or replace them). Mine were fine, although the grease was well diluted with gearbox oil that leaked out. I ust cleaned 'em and repacked them with grease.
14) Assembly is the reverse of the above.
15) Refill with suitable lube (ISO-68 Hydraulic oil or otherwise, just not detergent oil).
The seals are 35X45X10mm and two are required. My local power transmission outfit only had good quality seals in 7mm thickness. So, I simply fabricated a 6mm spacer to make up the difference between 10mm x2 and 7mm x 2. The spacer is 6061 aluminum, 44.9mm in diameter, 37.8 mm ID, and 6mm thick.
Alsoi check out this link for pictures of the insides. My PM-45MPDF is VERY similar.
http://www.graetech.com/index_files/Page975.htm
Any questions, just ask... It's still fresh in my mind and senility hasn't yet set in.
An interesting bit of trivia is that all of the internal breaings are sealed bearings. Considering the amount of particulate matter that was in there, I can understand why... I popped off the seals, cleaned out the bearings, and cleaned again, and again 'til they ran smooth, relubed, and replaced the seals.
One more thing: I used Permatex Ultra Black RTV gasket maker to seal the top cover and the seal "plate" inside the gearbox.
John
