Well, I've been restoring a 1947ish Craftsman 10" lathe. Today I got to the point of removing the headstock from the ways and found this:
And this:
So, the big break is right where the headstock clamped to the ways and the bolt hole for the rear is also broken. I suppose it was dropped or something.
anyway, does anyone have suggestions on a repair? I figure I can either weld it into place and make sure the welds are ground below the flat of the ways. Or I could possibly build a larger headstock clamp to catch more of the unbroken ways. I'd have see if that would even be possible or if I have the room but it may be an option. But from looking at the picture the clamp would have to have some notches.
What would you do?
Other than that it is cleaning up pretty well for being 75 years old.
On a side note, what is a good place to buy lubrication oils?
Thanks,
Dave
And this:
What would you do?
Thanks,
Dave
