I'm planning a round column-based QCTP similiar to this
http://www.gadgetbuilder.com/ToolHolders.html#Round_QCTP
....for my Sherline CNC lathe. My main reasons for the round column
format (vs. square dovetails-based versions) is the ease of tool holder
creation.In designing it to keep the cutting tools within the same space
the Sherline standard tools inhabit, while require the column to be
approximately 3/4" diameter, with a flat 1/8" square base for mounting
to the T-slots. As this is a bit narrower than the standard 1.25"
diameter square column Sherline tool holder, I am a bit concerned about
rigidity. My original plan was to go with aluminum, but knowing the
column diameter will be thin in encouraging me to go with steel. I use
this lathe for steel and stainless, so I think the aluminum would be
tool weak.
I'm looking for suggestions as to what steel I should select for the
tool post (and tool holders). I've considered stainless (merely because
of the corrosion resistance) but I'd rather lean on the side of
strength. I have no surface grinding capabilities but was also
considering steel that can be hardened (via propane/acetylene). I also
haven't ruled out that I'm over-engineering this and that simple
unhardened steel would be enough.
Any thoughts on the choice of metal?
tool weak.
