Ok... Dave and I got my new Sheldon into the basement, and I am reassembling it. It has a U drive...
I got the motor and U drive mechanism up into the cabinet (by myself I might add), put the belts back on, and wanted to make sure the handles fit the posts... I got a bit of paint in the holes...
Anyway... I shifted the speeds, while turning the pulleys slowly, and I have a problem. The right shift lever is not firmly connect to the mechanism on the end of it (that shifts speeds)... The lever moves about 180 degrees before engaging the mechanism.
There is a collar, with a set screw, and I believe that collar should fix the lever to the mechanism.
However... the set screw is stuck in there... won't move in or out. AND... hand to God... it was boogered up when I got there! My allen key was a sloppy fit the first time I put it in, and it just spun around in the set screw recess with a minimum of effort. The next size up will not fit, even with a little help, nor will any close metric key.
I REALLY don't want to remove this whole motor drive unit AGAIN... Yet I have very little access to this set screw.
Even with the drive unit out I won't have direct access, without at least partially taking apart the drive unit, which I don't really want to do...
Any ideas of how to remove this set screw without removing the U drive? How about with removing the drive? I don't have any left hand drill bits...
Thank you!!!
Steve
This first picture should show kind of where the set screw is... behind the painted part, just before the cast mechanism, on a collar... The next pictures show how far I need to move the handle before it engages... not acceptable. You can see the casting has moved, from the second picture to the third... it should be about a 45/60 degree throw...
and I imagine the overwhelming answer will be remove the motor and drive, and then something, something, something... crap!
Thank you!!!
Steve
