Hi all, I was at the right place at the right time and snatched up a really nice BP 2J several years ago in my travels with the intention of one day getting around to it. Well that time is here. I've managed to get it running without any difficulty. Every thing is working well as far as I can tell except the Ram travel that I just can't figure out. I've taken out the 2 long locking bolts on the right side facing the machine. I've taken out the round gear used to move the ram via the handle. From what I can tell nothing is stopping movement that I've missed, but Im not certain. I've taken a block of wood and gave it several good whacks at the back of those dovetails at the rear of the ram. Maybe Im too gentle. I've sprayed several days with Mr Wrench in all the areas I can reach in that vicinity followed by more smacks. I've also take a block of wood and raised the table to lift the ram at the dove tails in the front, and being very careful not to over do it. In fact, I can actually see tiny movement when I lift by the table where the ram meets the column on the sides below the words Bridgeport as the penetrating fluid bubbles out. I thought for sure since I can see that movement between the ram and column that it must not be seized. But when trying to move it by the handle it remain solid. Maybe some chips are blocking it somehow. The machine has never been in the weather. Born in 71. Reportedly only cut aluminum, and sat for 16 years before I got it. And then it sat in my garage for more years than I want to admit. Its a very clean machine. It did have aluminum chips everywhere. Everything is working great except I can't move the Ram. Any suggestions?
