I need to slot some screw heads and I hate messing with a 14 inch arbor with a dozen spacers on it and setting it up in the horizontal mill, so I made a stub arbor that is 2 inches long where the cutter fits and has an 11/16" stub to put in a collet. I made this 1 inch diameter one and it worked so well, I am going to make a couple more sizes. I put a center in the outer end so I can use the overarm for heavier work. Sometimes you just don't need a big heavy long arbor to do the job. The arbor was made from a 1 1/2" diameter cutoff and the spacers were made from some 1" nuts for bolts that were turned to 1 1/4" OD and bored to fit the arbor, then parted off to various lengths.
Mark
Mark
