- Jun 10, 2013
- 22
Have an old #2 "army" S&W somebody brazed the latch and hinge shut. (because it stretched?) This is a wall-hanger, will remain a wall hanger, but would be nice to have it be openable.
Thoughts on the procedure of removing the braze rod filler by dissolving into mercury amalgamation?
Might be able to separate under heat with oxy torch, but would have to mechanically remove the braze filler anyways from parts. Anyone know what metal these 1860's revolvers might be made of... steel type, high/low carbon, full iron, nickle/iron, because mercury wont normally attack Iron, but might attack the alloying metals.
Research points to being able to get at least a 30% copper mix into mercury but I find no mentions of how long a solid surface piece might take to dissolve, insomuch dentistry amalgams use a powderized metal dust and goes quickly into solution.
