They appear to be shock absorbers to cushion the closing action of mating parts, such as molds used in the pastics industry for high speed blow molding. Do they have a piston that moves in and out?
The shaft moves in and out 5/8in with an adjustable spring
tension. The other end appears to have a sight glass on it but
nothing comes out. It is solid plastic. Snugrat :headscratch:
