I have never used one of these. How do I calibrate to a known 18mm, 21mm or whatever starting size i fit the threaded tip, plus 1 or 2mm shims into the handle? For example when the 18mm tip is fitted with no shims, there is slightly less than 20mm uncompresed to the feeler tip, so how I do know or set things?
The dial indicator in itself is also strange. Why a 0-10mm range when the feeler handle has range of 1mm only? It appears to be original to the set, of course Borletti was making 5mm range instruments.
Also, is has a dampening function, provided by a flat coiled spring inside, so that the needle moves very slowly, like one division per second, in either direction. It's kind of painful to just watch it move.
